Aller au contenu principal
Dell Alienware 18 Coin-Cell Battery Replacement
Ce dont vous avez besoin
  1. Dell Alienware 18 Coin-Cell Battery Replacement, Before You Begin: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Coin-Cell Battery Replacement, Remove the base cover screws: étape 2, image 1 de 1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Coin-Cell Battery Replacement, Slide the Cover: étape 3, image 1 de 1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: étape 4, image 1 de 1
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  5. Dell Alienware 18 Coin-Cell Battery Replacement, Removing the Coin-Cell Battery: étape 5, image 1 de 1
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  6. Dell Alienware 18 Coin-Cell Battery Replacement, Prying the Coin-Cell Battery: étape 6, image 1 de 1
    • Pry up the coin-cell battery from the slot on the system board.
  7. Dell Alienware 18 Coin-Cell Battery Replacement, Placing Coin-Cell Battery: étape 7, image 1 de 1
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  8. Dell Alienware 18 Coin-Cell Battery Replacement, Routing the Coin-Cell Battery Cable: étape 8, image 1 de 1
    • Route the coin-cell battery cable through the routing guides on the computer base.
  9. Dell Alienware 18 Coin-Cell Battery Replacement, Connecting Coin-Cell Battery: étape 9, image 1 de 1
    • Connect the coin-cell battery cable to its connector on the system board.
Ligne d'arrivée
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 439
