Aller au contenu principal
Dell Alienware 18 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Dell Alienware 18 Hard Drive Replacement, Loosen the Screws: étape 2, image 1 de 1
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Dell Alienware 18 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 1 de 2 Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 2 de 2
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Dell Alienware 18 Hard Drive Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive: étape 6, image 1 de 1
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. Dell Alienware 18 Hard Drive Replacement, Sliding the Secondary Hard-Drive: étape 7, image 1 de 1
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Dell Alienware 18 Hard Drive Replacement, Secure the Screws: étape 8, image 1 de 1
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. Dell Alienware 18 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Dell Alienware 18 Hard Drive Replacement, Connecting the Interposer: étape 10, image 1 de 1
    • Connect the interposer to the hard drives.
  11. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 11, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  12. Dell Alienware 18 Hard Drive Replacement, Tightening the Screws: étape 12, image 1 de 1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Dell Alienware 18 Hard Drive Replacement, Connecting the Hard-Drive: étape 13, image 1 de 1
    • Connect the hard-drive cable to its connector on the system board.
Ligne d'arrivée
2 autres ont terminé cette réparation.
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 766
