Aller au contenu principal
Dell Alienware M17x R2 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Alienware M17x R2 Hard Drive Replacement, Loosen the Four Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Loosen the four captive screws that secure the primary hard drive (HDD0).
  2. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 2, image 1 de 2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 2, image 2 de 2
    • Using the pull tab, slide the primary hard drive (HDD0) towards the back of the hard drive bay and lift it out.
  3. Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: étape 3, image 1 de 3 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: étape 3, image 2 de 3 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: étape 3, image 3 de 3
    • If your computer has a secondary hard drive (HDD1): 1. Loosen the four captive screws on the secondary hard drive (HDD1). 2. Using the pull tab, lift the secondary hard drive (HDD1) out of the hard drive bay.
  4. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard drive bracket to the hard drive.
  5. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 5, image 1 de 2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 5, image 2 de 2
    • Slide the hard drive out of the hard drive bracket.
  6. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: étape 6, image 1 de 2 Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: étape 6, image 2 de 2
    • Remove the interposer from the secondary hard drive (HDD1), if applicable.
  7. Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: étape 7, image 1 de 2 Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: étape 7, image 2 de 2
    • Connect the NEW interposer to the secondary hard drive (HDD1), if applicable.
  8. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 8, image 1 de 2 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: étape 8, image 2 de 2
    • Slide the hard drive into the hard drive bracket.
  9. Dell Alienware M17x R2 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  10. Dell Alienware M17x R2 Hard Drive Replacement, Placing the Hard Drive: étape 10, image 1 de 1
    • Place the hard drive in the hard drive bay.
  11. Dell Alienware M17x R2 Hard Drive Replacement, Align and Tighten the Screws: étape 11, image 1 de 1
    • If your computer has a secondary hard drive (HDD1), align and tighten the four captive screws that secure the hard drive to the hard drive bay.
    • Align and and tighten the four captive screws that secure the primary hard drive (HDD0) to the hard drive bay.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 14
Total : 2,079
