Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
Loosen the two captive screws that secure the display cable to the system  board.
  • Loosen the two captive screws that secure the display cable to the system board.
Ajouter un commentaire
Using the pull-tab, pull the display cable to disconnect the display cable  from the connector on the system board.
  • Using the pull-tab, pull the display cable to disconnect the display cable from the connector on the system board.
Disconnect the camera cable and infrared cable from the respective system board connectors.
  • Disconnect the camera cable and infrared cable from the respective system board connectors.
Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables  from the routing guides on the palm rest assembly. Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables  from the routing guides on the palm rest assembly.
  • Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the six screws that secure the display assembly to the computer  base.
  • Remove the six screws that secure the display assembly to the computer base.
Lift the display assembly off the computer.
  • Lift the display assembly off the computer.
Place the NEW display assembly in position and replace the six screws that  secure the display assembly to the computer base. Place the NEW display assembly in position and replace the six screws that  secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the six screws that secure the display assembly to the computer base.
Route the display cable, camera cable, infrared cable, wirelessHD card  cable, and Mini-Card antenna cables  through the routing guides on the  palm rest assembly. Route the display cable, camera cable, infrared cable, wirelessHD card  cable, and Mini-Card antenna cables  through the routing guides on the  palm rest assembly.
  • Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
Connect the display cable to the connector on the system board.
  • Connect the display cable to the connector on the system board.
Tighten the two captive screws that secure the display cable to the system  board.
  • Tighten the two captive screws that secure the display cable to the system board.
Connect the camera cable and infrared  cable to the respective system  board connectors.
  • Connect the camera cable and infrared cable to the respective system board connectors.
Teren Wallace
Membre depuis le 18/12/2017
40 077 Réputation
357 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
833 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 19
