Aller au contenu principal
Dell Alienware M17x R3 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: étape 1, image 1 de 2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Remove the three screws that secure the memory-module cover to the palm rest assembly.
  2. Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: étape 2, image 1 de 3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: étape 2, image 2 de 3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: étape 2, image 3 de 3
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector un til the memory module pops up.
  3. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: étape 3, image 1 de 2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: étape 3, image 2 de 2
    • Remove the memory module from the memory-module connector.
  4. Dell Alienware M17x R3 Memory Modules Replacement, Align the Notch: étape 4, image 1 de 1
    • If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  5. Dell Alienware M17x R3 Memory Modules Replacement, Installing the Memory Module: étape 5, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Terrence15
Membre depuis le 12/18/17
79 091 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 503
