Aller au contenu principal
Dell Alienware M18x R2 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the Video-Card Connector Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Disconnect and peel off the video-card connector cable from the connectors on the system board.
  2. Dell Alienware M18x R2 Display Assembly Replacement, Pull the Pull-Tab: étape 2, image 1 de 1
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  3. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the LED Logo Board Cable: étape 3, image 1 de 1
    • Disconnect the LED-logo board cable from the connector on the system board.
  4. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Close the display and turn the computer over.
    • Remove the screws that secure the display assembly on the computer base.
  5. Dell Alienware M18x R2 Display Assembly Replacement, Note the Routing: étape 5, image 1 de 1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
    • Turn the computer over and open the display.
    • Note the routing of the display cable and LED-logo board cable, and then remove the cables from the routing guides on the palm-rest assembly.
  6. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: étape 7, image 1 de 1
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  7. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Antenna Cables: étape 8, image 1 de 1
    • Gently slide out the antenna cables through the slot on the computer base.
  8. Dell Alienware M18x R2 Display Assembly Replacement, Moving the Display: étape 9, image 1 de 1
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  9. Dell Alienware M18x R2 Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
    • Route the display cable and LED-logo board cable through the routing guides on the palm-rest assembly.
  10. Dell Alienware M18x R2 Display Assembly Replacement, Connecting the Display Cable: étape 12, image 1 de 1
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  11. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Cables: étape 13, image 1 de 1
    • Slide the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 17
Total : 1,081
