Aller au contenu principal
Dell Axim X30 Button Replacement
Ce dont vous avez besoin
  1. Dell Axim X30 Button Replacement, Buttons: étape 1, image 1 de 2 Dell Axim X30 Button Replacement, Buttons: étape 1, image 2 de 2
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Button Replacement: étape 2, image 1 de 2 Dell Axim X30 Button Replacement: étape 2, image 2 de 2
    • Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
  3. Dell Axim X30 Button Replacement: étape 3, image 1 de 1
    • Remove four 12.7mm JIS #0 screws.
  4. Dell Axim X30 Button Replacement: étape 4, image 1 de 1
    • Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel will pop off easily.
  5. Dell Axim X30 Button Replacement: étape 5, image 1 de 3 Dell Axim X30 Button Replacement: étape 5, image 2 de 3 Dell Axim X30 Button Replacement: étape 5, image 3 de 3
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Button Replacement: étape 6, image 1 de 2 Dell Axim X30 Button Replacement: étape 6, image 2 de 2
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Button Replacement: étape 7, image 1 de 1
    • Carefully remove motherboard.
  8. Dell Axim X30 Button Replacement: étape 8, image 1 de 1
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Button Replacement: étape 9, image 1 de 2 Dell Axim X30 Button Replacement: étape 9, image 2 de 2
    • Remove black plastic board.
  10. Dell Axim X30 Button Replacement: étape 10, image 1 de 2 Dell Axim X30 Button Replacement: étape 10, image 2 de 2
    • Remove grey and green membrane buttons.
Jonathan Gulley
Membre depuis le 03/28/18
187 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G5, Harley Spring 2018 Membre de l'équipe IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 413
