Aller au contenu principal
Dell Chromebook 11 3180 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 11 3180 Keyboard Replacement, Back Cover: étape 1, image 1 de 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Keyboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Keyboard Replacement: étape 3, image 1 de 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Keyboard Replacement: étape 4, image 1 de 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Keyboard Replacement: étape 5, image 1 de 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Keyboard Replacement, Keyboard: étape 6, image 1 de 1
    • Disconnect the ribbon cable from the motherboard. To do this, lift up the black tab hinge securing the ribbon cable and pull the cable up and then out of the port.
  7. Dell Chromebook 11 3180 Keyboard Replacement: étape 7, image 1 de 1
    • Release the keyboard from the body. To do this, push on the two keyboard release holes with something thin and cylindrical like a spudger or a pencil.
  8. Dell Chromebook 11 3180 Keyboard Replacement: étape 8, image 1 de 1
    • Remove the keyboard from the body. To do this, use a plastic prying tool to get under the keyboard and pry it up from the computer body.
  9. Dell Chromebook 11 3180 Keyboard Replacement: étape 9, image 1 de 1
    • Once you have separated the keyboard and the body using a spudger or plastic opening tool, use your hands to pull it away from and off of the computer.
13 autres ont terminé cette réparation.
Devon Paul
Membre depuis le 04/26/17
1 206 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S22-G1, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 membres
8 tutoriels rédigés
Un commentaire
How I will fix the chromebook 11 now?
Federico Vazquez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 48
Total : 7,342
