Aller au contenu principal
Dell Chromebook 11 CB1C13 Letter & Number Key Replacement
Ce dont vous avez besoin
    • Check the 4 metal clips that are attached to the palmrest. Look for damaged or missing clips.
    • If any of the 4 clips are missing, you will not be able to proceed and will have to replace the entire palmrest.
    • Check the condition of the rubber spring/membrane. If it is torn or missing, you will not be able to proceed and will have to replace the entire palmrest.
    • If any clips are bent, carefully use your tweezer to bend them back in their original upright position. (See video)
  1. Dell Chromebook 11 CB1C13 Letter & Number Key Replacement, Check Plastic Bracket: étape 2, image 1 de 1
    • Check the plastic bracket for damage in these 6 areas.
  2. Dell Chromebook 11 CB1C13 Letter & Number Key Replacement, Check Key for damage: étape 3, image 1 de 1
    • Check the 4 main points of the key for damage.
    • Any damage in these areas will not allow the key to stay connected to the plastic bracket which sits underneath the key
    • While using tweezers, remove just the actually key (top layer only) . You want to try and remove the key without also removing the plastic bracket that sits right underneath the key.
    • Try to slightly pick at the corner of the key. This helps remove the key separately from the plastic bracket.
    • With tweezers, carefully start picking near the four corners where the 4 metal clips are securing the plastic bracket.
    • Line up the 2 outer corners and the bottom inner corners of the plastic bracket with the 4 metal clips connected to the palmrest.
    • Place the key on top of the plastic bracket and press down. If the plastic bracket is on correctly and securely, the key should easily snap into place.
    • Check if the key is secure by tapping around all sides of the key. This is a good test to make sure the metal clips are properly securing the plastic bracket and making sure that the plastic bracket can hold the key correctly.
7 autres ont terminé cette réparation.
Jon
Membre depuis le 08/18/13
3 921 Réputation
22 tutoriels rédigés
6 commentaires
thanks this helped a lot and fixed my Chromebook thanks.
Jaxson Cowell - Réponse
Glad to hear it helped Jaxson! I appreciate the positive feedback.
Jon -
I accidentally broke my chromebook from school and the plastic bracket is damaged, what should I do?
Jud Franks - Réponse
the plastic brackets are correctly intact but whenever i go to put the key it doesnt work and the key isnt damaged
Random Deku - Réponse
nvm the key just got in and the my chromebook is fixed
Random Deku -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 94
Total : 11,628
