Introduction
This guide will help you replace the battery of a Dell Chromebook 11-3120. Please have a safe, static-free place where you can place the battery after it has been removed from the device.
Pièces
Aucune pièce nécessaire.
Flip the device over so the bottom is facing up
  • Flip the device over so the bottom is facing up
  • Remove the 7 visible Philips screws from the device's bottom cover
Ajouter un commentaire
Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches. Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
  • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unplug the battery connector from the motherboard
  • Unplug the battery connector from the motherboard
Remove the two silver screws that hold the battery to the case
  • Remove the two silver screws that hold the battery to the case
  • Lift the battery straight out of the case and place it in a safe, static-free place
Dalton D
Membre depuis le 08/12/2017
184 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 19
