Aller au contenu principal
Dell DJ Disassembly
Ce dont vous avez besoin
  1. Dell DJ Disassembly, Dell DJ Disassembly: étape 1, image 1 de 3 Dell DJ Disassembly, Dell DJ Disassembly: étape 1, image 2 de 3 Dell DJ Disassembly, Dell DJ Disassembly: étape 1, image 3 de 3
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  2. Dell DJ Disassembly: étape 2, image 1 de 3 Dell DJ Disassembly: étape 2, image 2 de 3 Dell DJ Disassembly: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
    • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
    • Be sure to keep the 4mm screws together and organized on the device magnet plate.
  3. Dell DJ Disassembly: étape 3, image 1 de 3 Dell DJ Disassembly: étape 3, image 2 de 3 Dell DJ Disassembly: étape 3, image 3 de 3
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  4. Dell DJ Disassembly: étape 4, image 1 de 3 Dell DJ Disassembly: étape 4, image 2 de 3 Dell DJ Disassembly: étape 4, image 3 de 3
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
Ligne d'arrivée
William Abel
Membre depuis le 01/28/16
164 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 Membre de l'équipe USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016
USFSM-STEWART-S16S1G1
3 membres
5 tutoriels rédigés
Un commentaire
How did you get the logic board to slide past the scroll wheel ?
kf4qic - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 596
