Introduction
Use this guide to replace the fan inside of your Dell Dimension 4600.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Locate the case cover latch on the back of the computer.
  • Locate the case cover latch on the back of the computer.
Ajouter un commentaire
Using your index finger, slide and hold the cover latch down.
  • Using your index finger, slide and hold the cover latch down.
  • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
  • Grab the edge of the panel and slide it away from the case until it is removed.
Lay the computer flat on it's side so that you are looking down at all of the components.
  • Lay the computer flat on it's side so that you are looking down at all of the components.
  • Locate the fan and its black, red, and white power cable.
Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
  • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
Locate the release clip on the side of the fan and hold it down with your thumb.
  • Locate the release clip on the side of the fan and hold it down with your thumb.
While holding the release clip down, look on the outside of the case where the fan lies.
  • While holding the release clip down, look on the outside of the case where the fan lies.
  • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
3 autre(s) ont terminé cette réparation.
Tim
Membre depuis le 12/10/2011
61 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-10, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 membres
6 tutoriels rédigés
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 4,957
