Aller au contenu principal
Dell Dimension 4600 RAM Replacement
Ce dont vous avez besoin
  1. Dell Dimension 4600 RAM Replacement, Side Panel: étape 1, image 1 de 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 RAM Replacement: étape 2, image 1 de 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 RAM Replacement: étape 3, image 1 de 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 RAM Replacement, RAM: étape 4, image 1 de 1
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
  5. Dell Dimension 4600 RAM Replacement: étape 5, image 1 de 2 Dell Dimension 4600 RAM Replacement: étape 5, image 2 de 2
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
  6. Dell Dimension 4600 RAM Replacement: étape 6, image 1 de 2 Dell Dimension 4600 RAM Replacement: étape 6, image 2 de 2
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
13 autres ont terminé cette réparation.
Daniel Crawford
Membre depuis le 10/10/11
1 021 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-10, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 membres
11 tutoriels rédigés
Un commentaire
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 10,175
