Introduction
Replace the interface buttons if they have fallen out or are worn out from usage.
Pièces
Aucune pièce nécessaire.
Lay the monitor screen-down so the back screws are exposed.
  • Lay the monitor screen-down so the back screws are exposed.
  • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
Ajouter un commentaire
Gently lift and pull away the stand at a slight angle away from the monitor.
  • Gently lift and pull away the stand at a slight angle away from the monitor.
Locate the two holes on the bottom of the monitor. Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
  • Locate the two holes on the bottom of the monitor.
  • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
  • This task is much easier if two people pry simultaneously at each hole.
  • Continue prying along the entire edge of the monitor.
When finished prying, the plastic will partially fall away from the rest of the monitor. Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
  • When finished prying, the plastic will partially fall away from the rest of the monitor.
  • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
  • While holding the frames together, carefully flip the monitor over so it faces screen down.
  • Gently lift and remove remove the rear case from the monitor.
Locate the green interface button board. Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel. Lift the monitor interior away from the front cover.
  • Locate the green interface button board.
  • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
  • Lift the monitor interior away from the front cover.
Behind the front panel of the plastic cover lies the button strip.
  • Behind the front panel of the plastic cover lies the button strip.
  • Remove the buttons by gently pulling up on the strip.
  • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
Charley Grove
Membre depuis le 10/10/2011
89 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-36, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,723
