Aller au contenu principal
Dell Inspiron 11-3164 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3164 Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3164 Battery Replacement, Battery: étape 1, image 2 de 2
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 6 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 6mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3164 Battery Replacement: étape 2, image 2 de 2
    • Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around the laptop . Once all the way around the top and bottom half will separate.
    • When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
    • Use your metal pry tool again to push the ribbon holding clip up and remove the ribbon cable.
  3. Dell Inspiron 11-3164 Battery Replacement: étape 3, image 1 de 1
    • Use the J1 screw driver bit from earlier and unscrew the three size 4mm battery screws.
  4. Dell Inspiron 11-3164 Battery Replacement: étape 4, image 1 de 1
    • While using one hand to hold the laptop grab the power wire with the other hand and pull it out of it's port.
    • Carefully remove the battery pack from the case.
Michael Kendziora
Membre depuis le 02/14/18
781 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 268
