Aller au contenu principal
Dell Inspiron 1100 Display Assembly Removal
Ce dont vous avez besoin
  1. Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: étape 1, image 1 de 2 Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: étape 1, image 2 de 2
    • Follow the instructions in "Preparing to Work Inside the Computer."
    • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Close the display.
    • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
  2. Dell Inspiron 1100 Display Assembly Removal, Opening the Display Assembly: étape 2, image 1 de 1
    • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  3. Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: étape 3, image 1 de 1
    • Remove the two M2.5 x 5-mm screws from each hinge bracket.
  4. Dell Inspiron 1100 Display Assembly Removal, Disconnecting the Cable: étape 4, image 1 de 1
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  5. Dell Inspiron 1100 Display Assembly Removal, Lifting the Display Assembly: étape 5, image 1 de 1
    • Lift the display assembly up and out of the computer base.
Terrence15
Membre depuis le 12/18/17
79 131 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 349
