Aller au contenu principal
Dell Inspiron 1122 M102z Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • Follow the instructions in Before You Begin.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 1122 M102z Hard Drive Replacement, Disconnecting the Hard Drive: étape 2, image 1 de 1
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard Drive: étape 6, image 1 de 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 8, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 1122 M102z Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 9, image 1 de 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 250
