Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING:  Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
Ajouter un commentaire
Disconnect the display cable and the camera cable from the system board connectors.
  • Disconnect the display cable and the camera cable from the system board connectors.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two screws (one on each side) that secure the display assembly to the computer base.
  • Remove the two screws (one on each side) that secure the display assembly to the computer base.
Lift the display assembly off the computer.
  • Lift the display assembly off the computer.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables through the routing guides.
  • Route the Mini-Card antenna cables through the routing guides.
Teren Wallace
Membre depuis le 18/12/2017
40 107 Réputation
370 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
846 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 12
