Introduction
In this guide, we will show you how to remove and replace the Hard Drive.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  • Remove the two screws that secure the hard-drive assembly to the computer base.
Ajouter un commentaire
Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board. Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
  • Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard-drive bracket to the hard drive.
  • Remove the four screws that secure the hard-drive bracket to the hard drive.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Lift the hard-drive bracket off the hard drive.
  • Lift the hard-drive bracket off the hard drive.
Place the NEW hard drive in the hard-drive bracket.
  • Place the NEW hard drive in the hard-drive bracket.
Replace the four screws that secure the hard-drive bracket to the hard drive.
  • Replace the four screws that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the computer base.
  • Place the hard-drive assembly in the computer base.
Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
Replace the two screws that secure the hard-drive assembly to the computer base.
  • Replace the two screws that secure the hard-drive assembly to the computer base.
Teren Wallace
Membre depuis le 18/12/2017
40 077 Réputation
357 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
833 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 7
