Aller au contenu principal
Dell Inspiron 1200 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: étape 1, image 1 de 2 Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: étape 1, image 2 de 2
  2. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Dell Inspiron 1200 Display Assembly Replacement, Releasing the Retention Tabs: étape 3, image 1 de 1
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Antenna Cable: étape 4, image 1 de 1
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  5. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: étape 6, image 1 de 1
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  6. Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: étape 7, image 1 de 2 Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: étape 7, image 2 de 2
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  7. Dell Inspiron 1200 Display Assembly Replacement, Removing the Cables: étape 8, image 1 de 1
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  8. Dell Inspiron 1200 Display Assembly Replacement, Lifting the Display Assembly: étape 9, image 1 de 1
    • Lift the display assembly out of the computer base.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 230
