Introduction
In this guide, we will be showing you how to remove and replace the Memory Modules.
Pièces
Aucune pièce nécessaire.
Follow the instructions in "Before Working Inside Your Computer."
Ajouter un commentaire
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the module from the connector.
  • Remove the module from the connector.
NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
  • NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
  • Align the notch in the module edge connector with the tab in the connector slot.
Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
Replace the cover and tighten the captive screw. Replace the cover and tighten the captive screw.
  • Replace the cover and tighten the captive screw.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 7
