Aller au contenu principal
Dell Inspiron 13 1370 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 1370 Display Assembly Replacement, Dislodging the Antenna Cables: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Make a note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the routing guides on the computer base. Pull the cables away so that they are clear of the computer base.
  2. Dell Inspiron 13 1370 Display Assembly Replacement, Removing the Screws: étape 2, image 1 de 1
    • Remove the four screws that secure the display assembly to the computer base.
  3. Dell Inspiron 13 1370 Display Assembly Replacement, Sliding the Hinges: étape 3, image 1 de 1
    • Slide the hinges out of the slots in the computer base.
  4. Dell Inspiron 13 1370 Display Assembly Replacement, Lifting the Display Assembly: étape 4, image 1 de 1
    • Lift the display assembly off the computer base.
  5. Dell Inspiron 13 1370 Display Assembly Replacement, Sliding the Tabs: étape 5, image 1 de 1
    • Slide the tabs on the display hinges into the slots in the computer base.
  6. Dell Inspiron 13 1370 Display Assembly Replacement, Align the Display Assembly: étape 6, image 1 de 1
    • Align the display assembly with the computer base using the alignment posts on the computer base and set the display assembly in place. Ensure the display cable and Mini-Card antenna cables route correctly through the display hinge covers.
  7. Dell Inspiron 13 1370 Display Assembly Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the four screws that secure the display assembly to the computer base.
  8. Dell Inspiron 13 1370 Display Assembly Replacement, Routing the Cables: étape 8, image 1 de 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 390
