Aller au contenu principal
Dell Inspiron 13 7368 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 7368 Memory Modules Replacement, Disconnecting the Battery Cable: étape 1, image 1 de 1
  2. Dell Inspiron 13 7368 Memory Modules Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Battery: étape 3, image 1 de 1
    • Lift the battery off the palm-rest assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Screw Holes: étape 5, image 1 de 1
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
  5. Dell Inspiron 13 7368 Memory Modules Replacement, Replace the Screws: étape 6, image 1 de 1
    • Replace the screws that secure the battery to the palm-rest assembly.
  6. Dell Inspiron 13 7368 Memory Modules Replacement, Connecting the Battery Cable: étape 7, image 1 de 1
    • Connect the battery cable to the system board.
  7. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: étape 8, image 1 de 1
  8. Dell Inspiron 13 7368 Memory Modules Replacement, Popping up the Memory Module: étape 9, image 1 de 1
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  9. Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: étape 10, image 1 de 2 Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: étape 10, image 2 de 2
    • Remove the memory module from the memory-module slot.
  10. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: étape 11, image 1 de 1
    • Lift the Mylar to access the memory-module slot.
  11. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Notch: étape 12, image 1 de 1
    • Align the notch on the memory module with the tab on the memory-module slot.
  12. Dell Inspiron 13 7368 Memory Modules Replacement, Sliding the Memory Module: étape 13, image 1 de 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 131 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 438
