Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
Ajouter un commentaire
Open the display as far as possible.
  • Open the display as far as possible.
  • Pull the pull-tab to disconnect the display cable from the connector on the system board.
Remove the display cable grounding screw.
  • Remove the display cable grounding screw.
  • NOTE: Open the display at a 90-degree angle to the plane.
In sequential order (indicated on the display hinge), remove the four screws that secure the display assembly to the computer base.
  • In sequential order (indicated on the display hinge), remove the four screws that secure the display assembly to the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the display assembly off the computer.
  • Lift the display assembly off the computer.
Place the NEW display assembly in position.
  • Place the NEW display assembly in position.
In sequential order (indicated on the display hinge), replace the four screws that secure the display assembly to the computer base.
  • In sequential order (indicated on the display hinge), replace the four screws that secure the display assembly to the computer base.
Connect the display cable to the connector on the system board.
  • Connect the display cable to the connector on the system board.
Replace the display cable grounding screw.
  • Replace the display cable grounding screw.
Turn the computer over and replace the two screws that secure the display assembly to the computer base.
  • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 18
