Aller au contenu principal
Dell Inspiron 13 N3010 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Screw: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 13 N3010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: étape 2, image 1 de 1
    • Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  3. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Four Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket away from the hard drive.
  6. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: étape 6, image 1 de 2 Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: étape 6, image 2 de 2
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 8, image 1 de 1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron 13 N3010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: étape 9, image 1 de 1
    • Slide and connect the hard-drive assembly to the system board connector.
  10. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screw: étape 10, image 1 de 1
    • Replace the screw that secures the hard-drive assembly to the system board.
    • Turn over the system board assembly.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 673
