Aller au contenu principal
Dell Inspiron 13-7359 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: étape 1, image 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: étape 2, image 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: étape 3, image 1 de 3 Dell Inspiron 13-7359 Battery Replacement: étape 3, image 2 de 3 Dell Inspiron 13-7359 Battery Replacement: étape 3, image 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: étape 4, image 1 de 3 Dell Inspiron 13-7359 Battery Replacement: étape 4, image 2 de 3 Dell Inspiron 13-7359 Battery Replacement: étape 4, image 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
4 autres ont terminé cette réparation.
Valentin Medina
Membre depuis le 01/30/18
697 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G6, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 membres
5 tutoriels rédigés
Un commentaire
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 1,570
