Introduction
In this guide, we will show you how to remove and replace the Memory Module.
Follow the procedures in Before You Begin.
  • Follow the procedures in Before You Begin.
  • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
  • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Ajouter un commentaire
Remove the module from the connector.
  • Remove the module from the connector.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Align the notch in the module edge connector with the tab in the connector slot.
  • Align the notch in the module edge connector with the tab in the connector slot.
Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place,  remove the module and reinstall it.
  • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
  • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4
