Aller au contenu principal
Dell Inspiron 1320 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1320 Display Assembly Replacement, Disconnecting the Display Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Disconnect the display cable and the camera cable from their respective system board connectors.
  2. Dell Inspiron 1320 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 1320 Display Assembly Replacement, Dislodging the Antenna Cables: étape 3, image 1 de 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Lift the display assembly off the computer.
  4. Dell Inspiron 1320 Display Assembly Replacement, Placing the Display Assembly: étape 5, image 1 de 1
    • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Route the Mini-Card antenna cables through the routing guides.
  5. Dell Inspiron 1320 Display Assembly Replacement, Connecting the Display Cable: étape 7, image 1 de 1
    • Connect the display cable and the camera cable to their respective system board connectors.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 264
