Introduction
In this guide, we will show you how to remove and replace the Hard Drive.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in  Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Remove the four screws that secure the hard drive assembly to the computer base.
Ajouter un commentaire
Slide the hard drive assembly to disconnect it from the system board connector.
  • Slide the hard drive assembly to disconnect it from the system board connector.
Pull the black pull-tab and lift the hard drive assembly out of the computer base.
  • Pull the black pull-tab and lift the hard drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard drive cage.
  • Remove the four screws that secure the hard drive to the hard drive cage.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Slide the hard drive out of the hard drive cage.
  • Slide the hard drive out of the hard drive cage.
Slide the NEW hard drive into the hard drive cage. Slide the NEW hard drive into the hard drive cage.
  • Slide the NEW hard drive into the hard drive cage.
Replace the four screws that secure the hard drive to the hard drive cage.
  • Replace the four screws that secure the hard drive to the hard drive cage.
Place the hard drive assembly in the computer base.
  • Place the hard drive assembly in the computer base.
Slide and connect the hard drive assembly to the system board connector.
  • Slide and connect the hard drive assembly to the system board connector.
Replace the four screws that secure the hard drive assembly to the computer base.
  • Replace the four screws that secure the hard drive assembly to the computer base.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
40 077 Réputation
352 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
828 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 9
