Aller au contenu principal
Dell Inspiron 13z N301z Hard-Drive Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Removing the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Connector Latch: étape 2, image 1 de 1
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: étape 5, image 1 de 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: étape 5, image 2 de 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Disconnecting the Interposer: étape 6, image 1 de 1
    • Pull the interposer to disconnect it from the hard drive.
  7. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Connecting the Interposer: étape 7, image 1 de 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: étape 8, image 1 de 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: étape 8, image 2 de 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive Assembly: étape 10, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  11. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Cable: étape 11, image 1 de 1
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 206
