Aller au contenu principal
Dell Inspiron 13z N311z Hard-Drive Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Remove the Screw: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the screw that secures the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Bracket: étape 2, image 1 de 1
    • To avoid damage to the hard drive, gently slide the hard-drive bracket away from the hard-drive slot.
  3. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lift the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Removing the Screws: étape 4, image 1 de 1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lifting the Hard Drive: étape 5, image 1 de 2 Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Lifting the Hard Drive: étape 5, image 2 de 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Align the Screw Holes: étape 6, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: étape 8, image 1 de 1
    • Place the NEW hard-drive assembly in the computer base.
  9. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: étape 9, image 1 de 1
    • Slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 13z N311z Hard-Drive Assembly Replacement, Replace the Screw: étape 10, image 1 de 1
    • Replace the screw that secures the hard-drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 131 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 5
Total : 215
