Introduction
In this guide, we will show you how to remove and replace the Hard Drive.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
  • Remove the screws that secure the hard-drive assembly to the computer base.
Ajouter un commentaire
Open the latch and disconnect the hard-drive cable from the system board. Open the latch and disconnect the hard-drive cable from the system board.
  • Open the latch and disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the computer base.
  • Lift the hard-drive assembly off the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive.
  • Remove the screws that secure the hard-drive bracket to the hard drive.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the hard-drive bracket off the hard drive.
  • Lift the hard-drive bracket off the hard drive.
Disconnect the interposer from the hard drive.
  • Disconnect the interposer from the hard drive.
Connect the interposer to the NEW hard drive.
  • Connect the interposer to the NEW hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the  hard drive.
  • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
  • Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the  computer base.
  • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
  • Replace the screws that secure the hard-drive assembly to the computer base.
Slide the hard-drive cable into the system board and close the latch to secure the cable. Slide the hard-drive cable into the system board and close the latch to secure the cable.
  • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
41 463 Réputation
374 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
850 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 9
