Introduction
How to remove and replace the Base Cover.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
Ajouter un commentaire
Remove the eight screws that secure the base cover to the palm-rest assembly.
  • Remove the eight screws that secure the base cover to the palm-rest assembly.
Remove the two screws that secure the base cover to the palm-rest assembly.
  • Remove the two screws that secure the base cover to the palm-rest assembly.
Remove the three screws that secure the base cover to the palm-rest assembly.
  • Remove the three screws that secure the base cover to the palm-rest assembly.
Turn the computer over, and open the display.
  • Turn the computer over, and open the display.
Open the latch, and disconnect the optical-drive cable from the system board.
  • Open the latch, and disconnect the optical-drive cable from the system board.
Close the display, and turn the computer over
  • Close the display, and turn the computer over
Using a plastic scribe, pry the base cover off the palm-rest assembly.
  • Using a plastic scribe, pry the base cover off the palm-rest assembly.
Lift the base cover off the palm-rest assembly.
  • Lift the base cover off the palm-rest assembly.
Release the optical-drive interposer from the tabs, and remove it from the base cover.
  • Release the optical-drive interposer from the tabs, and remove it from the base cover.
Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
Close the display, and turn the computer over.
  • Close the display, and turn the computer over.
Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
Replace the eight screws  that secure the base cover to the palm-rest assembly.
  • Replace the eight screws that secure the base cover to the palm-rest assembly.
Ligne d'arrivée
darrius
Membre depuis le 26/03/2018
4 385 Réputation
27 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
822 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 31
Total : 54
