Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer. Peel off the tape and disconnect the display cable from the system board.
Ajouter un commentaire
Note the display cable routing and remove the cable from its routing guide.
  • Note the display cable routing and remove the cable from its routing guide.
Disconnect the antenna cables from the wireless card.
  • Disconnect the antenna cables from the wireless card.
Peel off the tape that secures the antenna cables to the speaker.
  • Peel off the tape that secures the antenna cables to the speaker.
Note the antenna cable routing and remove the cables from their routing guide.
  • Note the antenna cable routing and remove the cables from their routing guide.
Using the pull-tab, disconnect the I/O-board cable from the I/O board.
  • Using the pull-tab, disconnect the I/O-board cable from the I/O board.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Note the I/O-board cable routing and remove the cable from its routing guide.
  • Note the I/O-board cable routing and remove the cable from its routing guide.
Remove the screws that secure the display assembly to the computer base.
  • Remove the screws that secure the display assembly to the computer base.
Lift the display assembly off the computer base.
  • Lift the display assembly off the computer base.
Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
Replace the screws that secure the display assembly to the computer base.
  • Replace the screws that secure the display assembly to the computer base.
Route the I/O-board cable through the routing guides on the computer base.
  • Route the I/O-board cable through the routing guides on the computer base.
Connect the I/O-board cable to the I/O board.
  • Connect the I/O-board cable to the I/O board.
Route the antenna cables through the routing guides on the computer base.
  • Route the antenna cables through the routing guides on the computer base.
Adhere the tape securing the antenna cables to the speaker.
  • Adhere the tape securing the antenna cables to the speaker.
Connect the antenna cables to the wireless card.
  • Connect the antenna cables to the wireless card.
Route the display cable through the routing guides on the computer base.
  • Route the display cable through the routing guides on the computer base.
Connect the display cable to the system board and adhere the tape.
  • Connect the display cable to the system board and adhere the tape.
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 24
