Aller au contenu principal
Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: étape 1, image 1 de 1
  2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: étape 2, image 1 de 1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: étape 3, image 1 de 1
    • Remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: étape 4, image 1 de 1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: étape 5, image 1 de 1
    • Lift the display-cable bracket off the system board.
  6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: étape 6, image 1 de 1
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: étape 7, image 1 de 1
    • Peel off the display cable from the computer base.
  8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: étape 8, image 1 de 1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: étape 9, image 1 de 1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: étape 10, image 1 de 1
    • Turn the computer over and open the display.
  11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: étape 11, image 1 de 1
  12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: étape 12, image 1 de 1
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: étape 13, image 1 de 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: étape 14, image 1 de 1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: étape 15, image 1 de 1
    • Close the display and turn the computer over.
  16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: étape 16, image 1 de 1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: étape 17, image 1 de 1
    • Adhere the display cable and the camera cable to the computer base.
  18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: étape 18, image 1 de 1
    • Connect the display cable and camera cable to the system board.
  19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: étape 19, image 1 de 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: étape 20, image 1 de 1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 107
