Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • Remove the two screws that secure the display assembly to the computer base.
Ajouter un commentaire
Turn the computer over and open the display as far as possible.
  • Turn the computer over and open the display as far as possible.
Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw. Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
  • Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
  • Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
  • Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables and display cable through the routing guides.
  • Route the Mini-Card antenna cables and display cable through the routing guides.
Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
Close the display and turn the computer over.
  • Close the display and turn the computer over.
Replace the two screws that secure the display assembly to the computer base.
  • Replace the two screws that secure the display assembly to the computer base.
  • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 4
