Introduction
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ce dont vous avez besoin
Remove the two screws that secure the hard-drive assembly to the system board.
Slide the hard-drive assembly to disconnect it from the connector on the system board.
Lift the hard-drive assembly away from the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
Slide and push the hard-drive assembly to connect it to connector on the system board.
Replace the two screws that secure the hard-drive assembly to the system board.
