Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information  that shipped with your computer. Follow the instructions in "Before You Begin".
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Disconnect the display cable from the connector on the system board.
Ajouter un commentaire
Disconnect the Mini-Card antenna cables from the connectors on the  Mini-Card.
  • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
Make a note of the display cable and Mini-Card antenna cables routing  and remove the cables from the routing guides.
  • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two screws that secure the display assembly to the computer  base.
  • Remove the two screws that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
  • Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the two screws that  secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
Route the display cable and Mini-Card  antenna cables through the routing  guides.
  • Route the display cable and Mini-Card antenna cables through the routing guides.
Connect the display cable to the connector on the system board.
  • Connect the display cable to the connector on the system board.
Connect the Mini-Card antenna cables to the Mini-Card. Connect the Mini-Card antenna cables to the Mini-Card.
  • Connect the Mini-Card antenna cables to the Mini-Card.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
40 107 Réputation
370 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
846 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 15
