Introduction
This step-by-step guide will show how to replace the RAM (Random Access Memory) stick in your Inspiron 14-3452 with a new one. All you need is a spudger and a screwdriver.
Pièces
Aucune pièce nécessaire.
Remove the battery by sliding the battery release latch to the left. Pull the entire battery away from the backing.
  • Remove the battery by sliding the battery release latch to the left.
  • Pull the entire battery away from the backing.
Ajouter un commentaire
Ensure that the laptop is completely turned off and the battery is removed.
  • Ensure that the laptop is completely turned off and the battery is removed.
  • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull the backing away from the laptop.
  • Pull the backing away from the laptop.
Locate the blue RAM chip sitting in the RAM bay.
  • Locate the blue RAM chip sitting in the RAM bay.
  • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
Pull the RAM chip away from the memory-module slot.
  • Pull the RAM chip away from the memory-module slot.
  • The RAM chip is now fully detached and ready to be replaced.
Alec Siegel
Membre depuis le 30/01/2018
505 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 70
