Aller au contenu principal
Dell Inspiron 14-5415 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-5415 Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Battery Replacement: étape 2, image 1 de 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Battery Replacement, Battery: étape 3, image 1 de 1
    • Remove the five 3 mm screws that secure the battery to the palm-rest and keyboard assembly using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Battery Replacement: étape 4, image 1 de 3 Dell Inspiron 14-5415 Battery Replacement: étape 4, image 2 de 3 Dell Inspiron 14-5415 Battery Replacement: étape 4, image 3 de 3
    • Carefully disconnect the battery cable from the system board.
    • Pulling on the cable with too much force could cause it to break or damage. Make sure to be gentle while completing this step, as it should not require any additional force.
  5. Dell Inspiron 14-5415 Battery Replacement: étape 5, image 1 de 3 Dell Inspiron 14-5415 Battery Replacement: étape 5, image 2 de 3 Dell Inspiron 14-5415 Battery Replacement: étape 5, image 3 de 3
    • Lift the battery off the palm-rest and keyboard assembly.
To reassemble your device, follow these steps in reverse order.
Lorraine N. Cosme Diaz
Membre depuis le 02/09/23
124 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 460
