Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Remove the two screws from the computer base.
Ajouter un commentaire
Loosen the display cable grounding screw.
  • Loosen the display cable grounding screw.
Disconnect the display cable from the connector on the system board.
  • Disconnect the display cable from the connector on the system board.
Remove the four screws that secure  the display assembly to the computer  base.
  • Remove the four screws that secure the display assembly to the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the display assembly off the computer base.
  • Lift the display assembly off the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Route the display cable and Mini-Card antenna cables through the routing  guides.
  • Route the display cable and Mini-Card antenna cables through the routing guides.
Connect the display cable to the  connector on the system board.
  • Connect the display cable to the connector on the system board.
Tighten the display cable grounding screw.
  • Tighten the display cable grounding screw.
Replace the two screws at the bottom of the computer.
  • Replace the two screws at the bottom of the computer.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1
