Aller au contenu principal
Dell Inspiron 1464 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1464 Display Assembly Replacement, Pull the Cables Up: étape 3, image 1 de 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: étape 4, image 1 de 1
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1464 Display Assembly Replacement, Disconnect the Display Cable: étape 5, image 1 de 1
    • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
  6. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1464 Display Assembly Replacement, Removing the Display Assembly: étape 7, image 1 de 1
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1464 Display Assembly Replacement, Placing the Display Assembly: étape 8, image 1 de 1
    • Use the alignment posts to place the NEW display assembly on the computer base.
  9. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the three screws that secure the display assembly to the computer base.
  10. Dell Inspiron 1464 Display Assembly Replacement, Connecting the Display Cable: étape 10, image 1 de 1
    • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
  11. Dell Inspiron 1464 Display Assembly Replacement, Routing the Cables: étape 11, image 1 de 1
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1464 Display Assembly Replacement, Thread the Cables: étape 12, image 1 de 1
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: étape 13, image 1 de 1
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 284
