Aller au contenu principal
Dell Inspiron 14R 5420 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14R 5420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Dell Inspiron 14R 5420 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14R 5420 Hard Drive Replacement, Remove the Cable: étape 3, image 1 de 1
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 14R 5420 Hard Drive Replacement, Lifting the Hard Drive Assembly: étape 4, image 1 de 1
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Dell Inspiron 14R 5420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: étape 5, image 1 de 1
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Dell Inspiron 14R 5420 Hard Drive Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14R 5420 Hard Drive Replacement, Sliding the Hard Drive: étape 7, image 1 de 2 Dell Inspiron 14R 5420 Hard Drive Replacement, Sliding the Hard Drive: étape 7, image 2 de 2
    • Slide the hard-drive off the hard-drive bracket.
  8. Dell Inspiron 14R 5420 Hard Drive Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14R 5420 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the NEW hard drive.
  10. Dell Inspiron 14R 5420 Hard Drive Replacement, Connecting the Hard-Drive Cable: étape 10, image 1 de 1
    • Connect the hard-drive cable interposer to the hard drive.
  11. Dell Inspiron 14R 5420 Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 11, image 1 de 1
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  12. Dell Inspiron 14R 5420 Hard Drive Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14R 5420 Hard Drive Replacement, Routing the Hard Drive Cable: étape 13, image 1 de 1
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Dell Inspiron 14R 5420 Hard Drive Replacement, Connecting the Hard Drive Cable: étape 14, image 1 de 1
    • Connect the hard-drive cable to the system-board connector.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 911
