Aller au contenu principal
Dell Inspiron 14R SE 7420 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Removing the Cable: étape 3, image 1 de 1
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 4, image 1 de 1
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Pull the Interposer: étape 5, image 1 de 1
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Sliding the Hard Drive: étape 7, image 1 de 1
    • Slide the hard-drive off the hard-drive bracket.
  8. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Interposer: étape 10, image 1 de 1
    • Connect the hard-drive cable interposer to the hard drive.
  11. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Place the Hard-Drive Assembly: étape 11, image 1 de 1
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  12. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Routing the Hard-Drive Cable: étape 13, image 1 de 1
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Hard Drive Cable: étape 14, image 1 de 1
    • Connect the hard-drive cable to the system-board connector.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 220
