Introduction
In this guide, we will be showing you how to remove and replace the Memory Modules.
WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
  • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
  • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Ajouter un commentaire
Remove the memory module from the memory-module connector.
  • Remove the memory module from the memory-module connector.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Align the notch on the NEW memory module with the tab on the memory-module connector.
  • Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
40 107 Réputation
370 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
846 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1
