Aller au contenu principal
Dell Inspiron 14z 1470 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 14z 1470 Display Assembly Replacement, Disconnecting the Display Cable: étape 2, image 1 de 1
    • Disconnect the display cable and remove the screw from the system board.
  3. Dell Inspiron 14z 1470 Display Assembly Replacement, Pull the Antenna Cables: étape 3, image 1 de 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 14z 1470 Display Assembly Replacement, Note the Routing: étape 4, image 1 de 1
    • Note the routing of all the cables and remove them from their routing guides.
  5. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: étape 5, image 1 de 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: étape 5, image 2 de 2
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  6. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display Assembly: étape 6, image 1 de 1
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 14z 1470 Display Assembly Replacement, Place the Display Assembly: étape 7, image 1 de 1
    • Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14z 1470 Display Assembly Replacement, Routing the Antenna Cables: étape 8, image 1 de 1
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  9. Dell Inspiron 14z 1470 Display Assembly Replacement, Route the Antenna Cables: étape 9, image 1 de 1
    • Route the antenna cables through the slot in the computer base.
  10. Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: étape 10, image 1 de 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: étape 10, image 2 de 2
    • Replace the screw and connect the display cable.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 131 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 243
