Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Remove the two screws that secure the display assembly to the computer base.
Ajouter un commentaire
Turn the computer over and open the display as far as possible.
  • Turn the computer over and open the display as far as possible.
Lift the connector latch and disconnect the display cable from the connector on the system board.
  • Lift the connector latch and disconnect the display cable from the connector on the system board.
Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
  • Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the display assembly off the computer base.
  • Lift the display assembly off the computer base.
Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base. NOTE: Ensure that no cables are caught between the display assembly and the computer base.
  • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  • NOTE: Ensure that no cables are caught between the display assembly and the computer base.
Route the display, camera, and mini-card antenna cables through their routing guides.
  • Route the display, camera, and mini-card antenna cables through their routing guides.
Slide the display cable in the connector on the system board and press down the latch to secure the cable.
  • Slide the display cable in the connector on the system board and press down the latch to secure the cable.
Turn the computer over.
  • Turn the computer over.
  • Replace the two screws that secure the display assembly to the computer base.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1
