Introduction
In this guide, we will be showing you how to remove and replace the Hard Drive Assembly.
Ce dont vous avez besoin
Remove the four screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, slide the hard-drive assembly to disconnect it from the connector on the system board.
Lift the hard-drive assembly off the computer base.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the computer base.
Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
Replace the four screws that secure the hard-drive assembly to the computer base.
