Introduction
In this guide, we will be showing you how to remove and replace the Memory Modules.
Pièces
Aucune pièce nécessaire.
WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".  After working inside your computer, follow the instructions in "After Working Inside Your Computer".
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
  • Close the display and turn the computer over.
Ajouter un commentaire
Loosen the captive screw that secures the memory-module cover to the computer base.
  • Loosen the captive screw that secures the memory-module cover to the computer base.
Using your fingertips, lift and slide the memory-module cover out of the slots on the computer base.
  • Using your fingertips, lift and slide the memory-module cover out of the slots on the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the memory module from the memory-module connector.
  • Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
  • Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.If you do not hear the click, remove the memory module and reinstall it.
  • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.If you do not hear the click, remove the memory module and reinstall it.
Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
Tighten the captive screw that secures the memory-module cover to the computer base.
  • Tighten the captive screw that secures the memory-module cover to the computer base.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
40 077 Réputation
368 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
844 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 2
