Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
Ajouter un commentaire
Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base. Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
Note the display cable routing and remove the cable from its routing guides on the computer base.
  • Note the display cable routing and remove the cable from its routing guides on the computer base.
Remove the screws that secure the display hinges to the computer base.
  • Remove the screws that secure the display hinges to the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Carefully lift the display assembly off the computer base.
  • Carefully lift the display assembly off the computer base.
Align the screw holes on the display hinges with the screw holes on the computer base.
  • Align the screw holes on the display hinges with the screw holes on the computer base.
Replace the screws that secure the display hinges to the computer base.
  • Replace the screws that secure the display hinges to the computer base.
Route the display cable through its routing guides on the computer base. Route the display cable through its routing guides on the computer base.
  • Route the display cable through its routing guides on the computer base.
Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
  • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
  • Close the display and turn the computer over.
Ligne d'arrivée
Teren Wallace
Membre depuis le 18/12/2017
42 075 Réputation
381 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 5
Total : 5
